Old 08-03-2009, 11:27 AM
Edbu Edbu is offline
Code PO 420
I have a 2003 silverado 4.8L. 2wd with 130,000. I keep getting code 420. Any help? Does not seem to have an exaust leak.
Thanks
Old 08-03-2009, 01:17 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Code PO 420
Its letting you know that your catalytic converter efficiency is low. It has nothing to do with exhaust leaking
Old 08-03-2009, 07:43 PM
j cAT j cAT is offline
Re: Code PO 420
Thanks
swap down stream O2 sensors if problem dtc changes its the O2 sensor,,,if it don't change its the cat converter....
if these o2 sensors are 130,ooomi on them you need to replace them...100,ooomi is the recommended mileage to replace...
