Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 08-03-2009, 11:02 AM
Paul Buxe's Avatar
Paul Buxe Paul Buxe is offline
No power to fuel pump?
I just installed a new fuel pump and after hooking it up I can not get any power to the pump. If I jump power from the battery to the pump the pump runs fine and the car will start and run great. Is there a relay or some thing I'm missing of getting power to the pump? I was very carefull on getting the wires back on the pump in the correct position. Any help out there?
PAul
Paul Buxe
Panoz GTRO-0042 LS2 gone but not forgotten
Miata Chump Car
Mustang GT
Porsche Boxter (wife's ride)
Chev Suburban trailer hauler
Factory 5 Cobra Roadster, 392 stroker
You have to grow older, but you don't have to grow up
Old 08-03-2009, 02:35 PM
ASPMANN's Avatar
ASPMANN ASPMANN is offline
Re: No power to fuel pump?
Paul, check the fuel pump relay it is on top of the computer I had a problem with mine. Also try resetting inertia switch.
Good Luck
Jim
Panoz GTRA #39
Old chassis # 30
New chassis
Old 08-03-2009, 04:42 PM
David Eastman David Eastman is offline
There are two fuse blocks behind the switch panel on the console. I am not sure if the fuel pump is fused but it is something else to check.
David
