Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 08-03-2009, 03:34 AM
88alldae 88alldae is offline
Question fuel pump
where is my fuel pump located on my 1988 caprice? and also how do i know if its working properly?
Old 08-03-2009, 11:54 AM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Re: fuel pump
The fuel pump is located on the right side of the engine towards the front.
Just follow the fuel line from the carb, it goes to the fuel pump.
To check the pump, you will need a fuel pressure gauge to check the pressure output of the pump. Not sure what it should be but a service manual will tell you what the pressure range should be.
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 08-03-2009, 05:34 PM
CD Smalley CD Smalley is offline
Re: fuel pump
Actually it depends... If he has a 4.3L V6, he would have TBI and it would be in the fuel tank.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 08-03-2009, 07:59 PM
Blt2Lst's Avatar
Re: fuel pump
Good point.
I assumed it had a carb from his other post..
You know what happens when you assume things...
1992 Camry LE 2.2
1996 Suzuki RMX250
Old 08-03-2009, 09:36 PM
Re: fuel pump
I guess I missed his other post. If he's a V8, you're spot on. But I didn't see anything listed in a signature.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
