Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 08-03-2009, 03:07 AM
jhigs68 jhigs68 is offline
cracked engine block
what are the sign and symptoms of cracked engine block?how can i diagnose the damage?pls help..thanks
Old 08-03-2009, 03:34 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: cracked engine block
Physical signs can include excessive smoking from the exhaust, coolant or oil leaks under the engine, very rough running or not running at all.
Using a compression tester, indications of low or no compression in one cylinder, or similar compression values in adjacent cylinders. A leak-down test is more definitive since leaks in the cylinders can be better pinpointed.
Of course, most or all of these symptoms can be attributed to a leaking or blown head gasket or cracked or warped head as well. You can't know for sure until you pull it apart. Post back if you have further symptoms... Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 08-06-2009, 07:40 PM
rhandwor rhandwor is offline
A lot of cracked blocks occur between the pistons. A machine shop can bore and install cylinder liners for this problem.
Old 10-20-2009, 05:40 PM
Monkeytech Monkeytech is offline
Send a message via MSN to Monkeytech
good post! remember your reading should be 10% differences.
