93 Jimmy ABS bleeding help needed
Posted this in the general area but thought I would post here also...need help ASAP...
...was gravity bleeding my ABS brake system(no real problem with brakes,just changing the nasty fluid) and accidentally let the fluid reservoir run dry...how do I bleed the ABS control unit?...tried using a vacuum pump on the two bleeders on the CU but not getting a drop of fluid out....seems to be pulling air out but the fluid level isnt going down..dosnt look like its had fluid in it for a while...the ABS light has been on for years....HELP!!!! |
Re: 93 Jimmy ABS bleeding help needed
You need to take it to a shop that has a Tech I capable scanner to bleed the ABS unit.
Sorry...
1993 Olds Bravada 4.3L CPI 1999 GMC Safari SLE AWD 2002 Chevy Astro LT AWD |
I was afraid of that..thanks
