1-2 shift issue
when I put it in D look like it start in 3rd shift, but if I move it manually to 1 OR 2 it works fine. I changed filter and fluid but problem still there. I went to autozone and they gave me these codes:
-. P0753, 1-2 shift solenoid valve performance -. P0785, Transmission 3-2 shift solenoid -. P1860, TCC PWM solenoid electrical fault -. P0758, 2-3 shift solenoid valve performance -. P0740, Torque Converter clutch (TCC) enable circuit I read in another thread that cause could be the ignition switch because on blazers 97 it is a common problem on some of the codes causes, http://www.automotivehelper.com/topic633087.htm AND also the key does not turn to release position, I can take it out or put it back and turn on the car but when I try to turn it to release position it stuck before reach it I have blazer 97 2wd. |
Re: 1-2 shift issue
Your trouble does sound like it could be a the ignition switch. That little black box is the cause of alot of head ackes. You mite find this link very helpful: Good Luck....
http://www.automotiveforums.com/vbul...gnition+switch |
