Old 08-02-2009, 03:03 AM
bri g bri g is offline
Honda SMX
This was finished a few months back but forgot to take completed pictures of it
This was a fun 2 week project, not much modifications except for the excessive camber and lowered suspension + stretch wall old school wheels.
Paint is orange basecoat, topped with 3 coats of bronze nail polish and 2k clear coat.
Old 08-02-2009, 03:09 AM
mugenhb's Avatar
mugenhb mugenhb is offline
Re: Honda SMX
very nicely done, I am loving the wheels.
Steve
My name is steve feel free to use it
Old 08-02-2009, 05:16 AM
f-style's Avatar
f-style f-style is offline
Re: Honda SMX
COOL <3
what color
Old 08-02-2009, 08:53 AM
Re: Honda SMX
thanks mugenhb!
thanks fstyle, the color is actually a solid orange topped a few coats of bronze nail polish sprayed lightly giving it a metallic orange color and then clear coated
Old 08-02-2009, 09:11 AM
Simas17's Avatar
Simas17 Simas17 is offline
Re: Honda SMX
Nice model
Old 08-02-2009, 10:47 AM
haas-al's Avatar
haas-al haas-al is offline
Re: Honda SMX
Originally Posted by bri g View Post
thanks mugenhb!
what type of paint ? great clean build!
Old 08-02-2009, 11:22 AM
ton394's Avatar
ton394 ton394 is offline
Re: Honda SMX
nice build sir , btw what wheels is that?
Old 08-02-2009, 12:39 PM
Re: Honda SMX
haas-al, The basecoat orange is made by Krylon, cheap spraycan which I decanted for airbrush use. The nail polish didn't have a brand and the clearcoat I used is made by Anzahl.
ton394, these are fujimi volk mesh I believe and the stretch walls are urethane rubber casts that I made from aoshima tires
Old 08-02-2009, 01:44 PM
haas-al's Avatar
Re: Honda SMX
krylon which is used for graffiti or other series? I ask because i didn't find any acceptable paint from sprays.... one of my projects is now destroyed by spray auto paint... i need a lot of putty now... i'm using 2 components urethan paints or tamiya cans, and collecting information about different sprays....
Old 08-02-2009, 08:33 PM
Re: Honda SMX
haas-al, yup its the cheap krylon for graffiti and stuff what primer do you use? maybe the problem is with the primer? with automotive paint, you have to spray a lot more mist coats.
Old 08-02-2009, 08:34 PM
Lownslow's Avatar
Lownslow Lownslow is offline
Re: Honda SMX
thats gangsta
Old 08-05-2009, 01:45 AM
modelaholics's Avatar
modelaholics modelaholics is offline
Re: Honda SMX
Pardon my actual machanical knowledge of cars, it's not uncommon to see wheel mis-alignment in the builds, is it a real case for these type of tires or a common pitfall for modelers when lowering the ride height?
When I did mine, I found cutting short the shock absorber is easy, but lots of time of fine-tuning needed to put in for also modifying the swing arm, shaft and sometimes the chassis, just to make the wheels align.
Can any expert give some advice?
Old 08-05-2009, 01:56 AM
Re: Honda SMX
modelaholics, you're right that camber is normally affected when you lower your builds and most of the time, I would fix that as well to make sure the wheels are aligned and flushed with the fenders. In this case though, the exaggerated camber of the wheels were done on purpose just like the japanese bosozoku cars. I actually bent the metal axles in a V shape to get that tilt I guess its the Japanese's way to squeeze in super wide wheels in small fenders.
Old 08-05-2009, 02:20 AM
haas-al's Avatar
Re: Honda SMX
Tamiya spray primer... maybe that's it: i had to do some mist coats and let em dry, than increase intensity. But i didn't o that, all coats were done in 20 minutes,,,,
Old 08-05-2009, 02:47 AM
Re: Honda SMX
haas-al, I use tamiya primer as well. It looks like you need to let the primer dry a little more. I normally give it at least a few days, give it a light sand and then the color followed by 20 minutes inbetween coats.
