Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 08-02-2009, 12:39 AM
Rchtoney Rchtoney is offline
Newbie steering question
I have a 92 Tbird. The steering wheel wants to jump slightly to the right in left hand turns. No problems in right hand turns or driving straight. Just left. Any ideas? Thanks
Old 08-02-2009, 08:51 AM
Bob9646 Bob9646 is offline
Re: Newbie steering question
Jack it up check everything for play for starters, I would say you might have a bad connecting rod end
1996 Thunderbird lx 4.6L
Mods- PI top end swap, C&L plenum, 75mm throttle body, 03 mustang gt intake tube, airbox, 80mm MAFS, 300hp+ J-Mod, tuned really hot by Lonnie at Blue Oval Chips with an sct X3, mid length dual exhaust with mandrel bent X-pipe and turndowns
Up next- aluminum driveshaft, 22c plugs, 180 degree thermostat and a tune to match, polyurethane EVERYTHING, possibly lowering springs
Old 08-02-2009, 10:19 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Also, check the steering rack mounts.
Old 08-02-2009, 11:15 PM
Scrapper Scrapper is offline
AF Premium User
when your going strait ahead is your sterring wheel strait across and dose it shimmy? if so i'd check and see if you got a busted belt in tire. if these are no problems i'd say it was in the rack and also check sway bar bushings and or stable lizer links and bushings if not rack bushings?
Old 08-05-2009, 10:35 AM
Thanks for the advice, it was much appreciated. The car drives perfect straight, just left hand turns. After jacking it up, I can find no play in the wheel, tires are in good shape. Leaning toward the rack. Hard one to figure out.
Old 08-06-2009, 07:09 PM
Rotate your tires and see if anything changes, you might not be able to spot a problem tire visually
