Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 08-01-2009, 08:44 PM
dustywb1 dustywb1 is offline
97 gmc sierra fuel pump relay gets hot
the relay gets hot and shuts down the fuel pump let it cool off and truck starts again anyone know what the problem is
Old 08-20-2009, 01:43 AM
567234ta 567234ta is offline
Re: 97 gmc sierra fuel pump relay gets hot
typically a lot of resistant would cause it.
how many miles on the fuel pump? may be the fuel pump going bad or just the wiring is corroded
Old 09-12-2009, 06:26 PM
swensonb71 swensonb71 is offline
Send a message via Yahoo to swensonb71
it is the fuel pump going bad. had this same problem on a 99 silverado and 96 tahoe. replaced the fuel pump and never had it happen again.
Old 09-12-2009, 08:18 PM
brcidd's Avatar
brcidd brcidd is offline
That is why the oil pressure switch runs fuel pump gray wire in parallel- in case of fuel pump relay failure..
Your service manual fuel pump wiring diagram clearly shows the fuel pump relay in parallel with the oil pressure switch...and the text describes that it is this way in case of relay failure.....so how does the relay alone shut you down? you must have another problem- like a worn out fuel pump.....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 12-04-2009, 05:05 PM
i just had a bad conection on the the relay fixed and cleaned it and no problems in 3000 miles
