Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 08-01-2009, 06:18 PM
thsnowman thsnowman is offline
96-98 GM 5.7L injector voltage
1998(9)suburban (it's a 99 but old body style not newer) with 5.7L, CSFI. What is the voltage that the injectors use? I've heard 5V and 12V for GM injectors.
Have the spider assembly on my bench still trying to get this thing back to it's once (read ummmmm 4 days ago) glory, LOL. I want to open and close each one and see if I have a stuck injector. Also, anyone know how to get these darned things outta the housing?
I know, alotta questions for a noob, but heck, I have 2 '99 suburbans, maybe I am in for being a regular here......
Thanks for your time, God Bless.
-Scotty
Old 08-01-2009, 07:32 PM
777stickman 777stickman is offline
Re: 96-98 GM 5.7L injector voltage
12v is supplied to each injector thru the ECM 1 fuse. The VCM controls the ground for each injectors pulse width.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 08-01-2009, 07:43 PM
See this thread....
http://www.automotiveforums.com/vbul...d.php?t=960719
still trying to figure this thing out, got the spider out and want to check to see if the injectors are opening in all cylinders, 3, 5, 7 seem dead by temp readings. I assume 3, 5, 7 because temp at exhaust port manifold on #1 gave me 220, 3 and 5 gave me 160 and 7 gave me 115, could be the cast iron is dissipating the heat from 1 to 7 therefore the 160 would be close the middle of the low and high, meaning 3 and 5 are not firing, although the spark bites me something fierce when I pull a plug wire....
Thanks for the reply, starting to think didn't nobody looked at this forum anymore....
-Scotty
Old 08-04-2009, 09:24 AM
j cAT j cAT is offline
-Scotty
what is wrong with this vehicle ?
Or are you just looking/trying to figure out how injectors work...
Old 08-04-2009, 09:44 AM
See this thread....
