Old 08-01-2009, 02:21 PM
frehol frehol is offline
Transmission/transfer case seal ?
Blazer 95, 4.3l "W", auto tranny, 233 tc, 4x4
I checked fluid level in the transfer case (tc) and found out where all transsmission fluid I topped the transmission with...
When I removed the tc level/fill plug out came about two liters of fluid, no need to topp it up
So I recon the seal between tranny and tc needs to be replaced.
Is it hard to do?
How is it done?
/Freddy
Old 08-01-2009, 04:34 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Transmission/transfer case seal ?
Is it hard to do?
How is it done?
/Freddy
Yes it does.
Drain transmission down and drain transfer case and then Remove transfer case.
You will find the seal/seals/double seal in the transfer case input shaft housing.
Let us know how it goes
Good Luck
MT
