Old 08-01-2009, 01:59 PM
mtulett1 mtulett1 is offline
'01 cherokee engine replacement
My 4.0 l won't hold oil pressure @ idle. I even put 20w50 oil in it. Though i do get better gas mileage. Does this still mean that the engine is shot? or am I missing something? IF i do need to replace the engine, can anyone recommend a place to get one. Also i wouldn't mind selling it if someone wanted to take on a project.
thanks
Old 08-01-2009, 06:21 PM
ronaldk's Avatar
ronaldk ronaldk is offline
Re: '01 cherokee engine replacement
first change oil pressure sending unit I think on filter houing these go bad and if bad looks like you have no pressure. When in doubt you could put a real pressure gauge in to test but its probably sending unit. If that works you may want to put proper weight oil back in. Oh and ps heavier weight oil will not increase gas miles .Good luck post back
Old 08-01-2009, 07:45 PM
ya i have already replaced the sending unit. The increase gas milage is because the seals are all worn(probably)hence why i think i need a new engine. but thanks anyway
Old 08-01-2009, 08:13 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
How many miles? These engines usually last at least 250K miles.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 08-01-2009, 11:10 PM
ronaldk's Avatar
I would put real pressure gauge in place where electrical sending unit is so no guess work. If low and no eng knock I would change oil pump. The 4.0 eng one of the good ones. Good luck
Old 08-02-2009, 08:49 AM
only 146000 miles but the guy who owned it before me beat the tar out of it.
Old 08-03-2009, 12:49 PM
ronaldk's Avatar
146k is not that high miles for 4.0 but if you verify that pressure is low with real pressure gauge and eng has not started to knock and you have ablity to remove oil pan . then change oil pump its not lots of $$$$ and cant hurt who knows it may pressure up like new but if you do have v. low pressure and dont fix,then bottom end or rod could be next problem.
Old 08-03-2009, 07:34 PM
rhandwor rhandwor is offline
If the strainer isn't plugged I would check all the bearings before installing a new oil pump. Talk to your machine shop for other items to check.
Old 08-05-2009, 07:17 PM
thanks everyone!
