Old 07-31-2009, 11:23 PM
kozmicgirl kozmicgirl is offline
96 park ave
Hello every body i have a question and hope some one can and will answer it for me. Some one mention about they got three srews out the actuator is there anything dealing with the air bag close or near bye that actuator?
Old 08-02-2009, 01:59 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 96 park ave
Yes, but if you disconnect BOTH of your battery cables (negative side first) and touch the cables together to discharge any residual voltage, you should be fine. BTW, before disconnecting the cables, be sure to turn the A/C system OFF while the engine is running. This allows the system to set to the home position and hopefully will not display faults once the job is complete.
