Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 07-31-2009, 08:04 PM
HeWhoKillz HeWhoKillz is offline
3rd gear pop out
I have a 91 corolla 1.6. Third gear won't stay in place. The shifter pops back into neutral. Would it be better to replace the third gear? or what are some opinions on what this is or what to do or how to fix it. Or would it be best to just get a rebuilt or junkyard transmission?
Old 08-03-2009, 02:24 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 3rd gear pop out
I don't know exactly the cost comparison, that's really up to you to call around and ask after getting an informed opinion as to what the problem could be...broken shift fork? bad throw-out bearing? broken gear? Get estimates for fixing versus buying a used tranny and replacing.
If it were me, you would probably be slightly better off having yours repaired because no matter which way you go, the engine and tranny has to come out. With it out, they can replace the broken components, check and adjust the rest, install a new clutch plate and you'd get a good tranny with a decent warranty. Go used and you don't know what you'll get...sure they'll probably warranty it too and you'd get it back faster, but they likely won't crack the case and check it out before installing it. But you can ask for a newer lower-mileage tranny, albeit probably at a premium. Something like this you want done right the first time.
Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
