Old 04-03-2003, 05:20 PM
flylwsi flylwsi is offline
Send a message via AIM to flylwsi
twin scroll turbo...
how do they work, what do they do?
i've heard of them, know they were first used on the lancer evo (i think it was the evo III)...
any info would be great, it's one of the few things that i can't get my head around, and i've looked everywhere...
Old 04-04-2003, 07:50 PM
454Casull 454Casull is offline
A turbine section of a turbocharger with separate inlets for separate headers... e.g. a twin-scroll turbo could be used with two 3-1 headers (on a V-12, say).
I suppose they make for less exhaust restriction/backpressure.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 04-04-2003, 10:37 PM
FYRHWK1 FYRHWK1 is offline
Send a message via AIM to FYRHWK1
missed this one, the twin scroll is all about tuning, it keeps one exhaust pulse from reversing back to the head. Like a log manifold for example, shitty tuning since all the exhaust feeds into 1 log, a twin scroll lets a V6 or 8 stick 1 pair of header primaries into one side without worrying about the pulse from another reversing back up it, very good setup to use.
Old 04-05-2003, 12:24 PM
so it's basically like putting a turbo on the end of the first section of a header...
where it goes 4 into 2...
i figured it would be more complex than that...
thanks guys
Old 04-13-2003, 08:50 PM
thanks guys
What?
Old 04-13-2003, 11:57 PM
Porsche's Avatar
Porsche Porsche is offline
Pretty much amazing
Send a message via MSN to Porsche
LOL
ec437 on grammar;
Originally Posted by ec437
I'd've
Originally Posted by 2strokebloke
Any car built by "Dr. Technology" is probably not worth $5000
Old 04-14-2003, 04:14 PM
now i'm back to square one, b/c i'm pretty sure that neither post really explained anything here after rereading what was posted.
especially considering that i replied to 454 with the exact same thing he said.
any other takers to help me out?
Old 04-15-2003, 10:30 PM
texan's Avatar
texan texan is offline
Writer Mod
the twin scroll is just a more advanced tubine housing design that helps to enhance exhaust gass energy utilization while minimizing ehxaust manifold backpressure and hence potential for reversion.
Think of your average inline 4 cylinder. Ever notice how in 4-2-1 headers they always pair cylinder 1 with 4 and cylinder 2 with 3 when merging the 4 pipes into the 2 secondaries? The basic firing order dictates that pairing these cylinders together will give the longest possible gap between exhaust pulses traveling through the pipes, thus enhancing flow while minimizing reversion. The twin scroll operates with the same basic principle in mind: keep the cylinders firing into an exhaust pipe that isn't already stuffed full of exhaust from an adjacent cylinder. With turbo cars this can be especially important as at higher RPM exhaust backpressure is usually significantly higher than atmospheric pressure, and often higher than intake manifold pressure as well.
So the twin scroll creates two exhaust paths instead of one, allowing for that increased separation in exhaust flow that is key to keeping everything from stacking up behind the turbo and causing reversion. It also helps to preserve the exhaust velocity of each pulse by offering a smaller overall volume to hold each one, so the turbine impeller is more easily spun up by a given total amount of flow than an equivalent single scroll design. Or at least that's the theory behind them. Answer your questions?
'03 Corvette Z06
'99 Prelude SH
Old 04-16-2003, 11:06 AM
thanks, so i was right in thinking that it would be like putting a turbo onto a header where it merges 4-2, right?
that makes sense...
Old 04-16-2003, 11:12 AM
texan's Avatar
Writer Mod
Yes, that would be an accurate way to describe it.
'03 Corvette Z06
'99 Prelude SH
Old 04-16-2003, 02:32 PM
good, b/c that's what i said earlier, and the people who replied seemed a little dumbfounded.
thank you texan.
Old 04-18-2003, 11:35 AM
thank you texan.
It's just that I didn't understand you. Maybe if you said "2-1 headers".
Old 04-19-2003, 08:10 AM
but it's not 2 into 1.
it's where the 4 tubes go into 2.
which is what i said...
it's where the first Y's are at in the header setup, regardless of being 4 cyl, or 6...
so on a 4 cyl (or one side of a v8) it's where the 4 go into 2.
Old 04-19-2003, 08:26 AM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
I'm glad I didn't say anything earlier in this post, because I misread the question initially. I was going to describe a two-spool turbo, not a "twin-scroll" turbo. Completely different.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 04-19-2003, 12:03 PM
since you brought it up... what's a dual spool turbo?
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
