Old 04-03-2003, 04:55 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
mpfi swap
k ive been looking into past threads and stuff and i cant seem to find out what eveyrone else has doen.
ok so i am doing the mpfi swap right now, and i got a few questions about it. i got everything wired up in the engien bay. but i was curious about the ecu and the wire swaps and everything.
it says move the wires from c1 to b10 and c2 to b12, then it says run wires to a3 and a7.
k my question is does a3, a7, b10, b12 have pins already in the ecu harness ? or do i have to add pins, if so where do i get pins from ?
Team Lonely Drivers
Old 04-04-2003, 10:20 AM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
Pins are already in the harness.
Old 04-04-2003, 04:49 PM
well i ask because i did look at the harness wiring once but i forgot, i could ahve sworn there wasnt any ecu pin in b10 or b12. and i am reading my scc issue on the dpfi to mpfi, and they talk about adding ecu pins on the wires u add to the ecu harness.
can somebody plz double check this, because i know more than one of u guys have done a mpfi swap
Team Lonely Drivers
Old 04-05-2003, 12:40 AM
come on guys, one of u must have done a mpfi swap, hook a brotha up
Team Lonely Drivers
Old 04-05-2003, 11:12 AM
91civicDXdude's Avatar
the pins should already be in the harness.
Maybe you're not looking at the right pin.. get yourself an ECU pin out.
A=injector harness
B=middle harness
C=the other harness thats not in the middle or has injector wires
they are numbered in a zig zag pattern like if you were to sit the plug on its side, it woudl be numbered like this:
12
34
56
78
910
etc.
