Old 07-31-2009, 05:29 AM
tanobis tanobis is offline
98 z24 problems
ok i have a couple problems. my car will start up fine run normal then ill shut it off. and once in a while ill go to start it and it will just start ticking really fast and engine light will go on then all power will be drained after a couple trys, boosting it while its like this does not even work. but we will detach battery cables and clean them then it will start fine. also when im driving the ets light e-brake light and a couple more go on, and all the gauges drop to zero really fast for abbout a second when im accelerating then go back to normal. please help
Old 08-03-2009, 05:12 PM
PlanetDude PlanetDude is offline
Re: 98 z24 problems
Battery connection? I`m thinking at one end of one of the cables.... or internally.... check each end of the positive and negative cables carefully.... if they all check out ok, try wiggling.... other than that, I think you`ve got a nasty gremlin loose in there somewhere... good luck
Mine:
89 Honda Prelude Si - 2.0, 5-speed
98 Chevy Cavalier Z24 - 2.4, auto
Family`s: (which I do the work on)
05 Chevy Impala - 3.4, auto
02 Pontiac Grand Am - 2.2, auto
01 Chevy Silverado - 5.3, auto
92 GMC Sierra - 5.7, ext cab, auto
88 Chevy Celebrity - 2.8, auto
