Go Back   Automotive Forums Car Chat > Ford > Super Duty
Old 07-30-2009, 09:31 PM
motorsports12 motorsports12 is offline
99 f250 ball joint replacement (2 wheel drive)
has anyone replaced the ball joints on a twin i-beam f250 superduty 2 wheel drive ... if so can you walk me thorugh it
any help is appreciated
Old 08-02-2009, 07:46 PM
big white bufflo big white bufflo is offline
Re: 99 f250 ball joint replacement (2 wheel drive)
you may need a ball joint press for them you can rent them at auto zone but when you do them it wize to replace both so you do dont have to go back and do the other later i have done some but not the newer ford its timely but it can be done
Old 08-03-2009, 02:32 AM
Davescort97 Davescort97 is offline
Escort guy
Take off the brake calipers and the rotors. Remove the spindle/knuckle assembly with the ball joints attatched. Put it in a vise. Remove the lower ball joint. Undo the snap ring on the upper ball joint and press it off with a suitable tool. The installation is just the reverse order on the above.
