Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 07-30-2009, 04:06 PM
Flying Dutchman Flying Dutchman is offline
cylinder filling with fuel
This is a 97 with the 2.2L engine. What would cause the #4 cylinder to fill with fuel???
Mechanic not sure what to do and my pockets aren't deep enough for him to keep experimenting.
Changed the fuel regulator, and the injector and no improvement.
Next thought about trying a used fuel rail but in 97 it sounds like this is incorporated into the intake manifold.
If you have any ideas, I'd love to hear them...thanks
Old 08-09-2009, 11:03 PM
EvilGrogg EvilGrogg is offline
Re: cylinder filling with fuel
Have you checked to makes sure that Cylinder is getting spark. I am not sure if it would fill the cylinder with fuel but seems logical if it does not burn it, it cannot exhaust a sprayed liquid out of the top of the head that easily. Never had that happen so kinda grabbing at straws.. Hope it helps.
Good luck. Let us know what fixed it when you figure it out.
Old 08-09-2009, 11:36 PM
inafogg inafogg is offline
not sure but make sure injector isnt firing all the time.not sure if it gets grounded or pos.volt to fire??just a thought...
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 08-14-2009, 02:32 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
bad coil pack probably
or stuck injector
possibly
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 08-17-2009, 05:44 AM
rex1one's Avatar
rex1one rex1one is offline
Send a message via AIM to rex1one Send a message via Yahoo to rex1one
KISS: Have you checked that sparkplug or tried replacing it? A cheap thing to try. then swap two of the injectors if that doesn't work and see if another cyl fills up.
Of you haven't broken it then you haven't gotten any use out've it.
Old 12-14-2009, 12:03 AM
reino134 reino134 is offline
Send a message via AIM to reino134 Send a message via MSN to reino134 Send a message via Yahoo to reino134
Just replaced motor in a Sunfire and have the same problem, all four cylinders just fill up with fuel as soon as you hook up the battery. Did anyone figure out what causes this? Any help would be greatly appreciated.
Old 12-14-2009, 12:00 PM
maxwedge maxwedge is offline
A990 racer
Obviously the injectors are being held open confrim this with a noid lite if it stays on when turning the key on that is the issue, why is next. Check for a pinched wire from the injector harness for starters.
Old 12-14-2009, 03:32 PM
the injectors are hold open and fuel pump keeps on pumping, with the key on the off position. the only way to stop the fuel is to disconnect the battery cable
