Old 07-30-2009, 03:10 PM
chibbard05 chibbard05 is offline
99 Lasabre stalls
161K shuts off when driving. There are a lot of these types of threads but this seems a little bit different at least. Any help would be awesome, i have been at two different mechanics now and both seem hopeless.
The check engine light goes on and off intermittently and when it comes on, the engine has a tendency to die when i am not on the gas (often coming up to lights or stop signs). Also it idles strangely. it will go from 500RPM to 2000RPM in park without me doing anything and then sometimes just dies.
But then the next day the check engine light will be off and the car will run perfectly... for about 30min or so. please help
Old 07-30-2009, 03:16 PM
maxwedge maxwedge is offline
A990 racer
Re: 99 Lasabre stalls
There should be a code in history, when it stalls does it start right back up?
Old 07-30-2009, 03:18 PM
sorry the code is 102. the car always starts right back up but then sometimes it will just die right away unless i give it gas and try to throw it into drive. other times it starts great. I replaced the MAF but nothing changed.
Old 07-30-2009, 07:30 PM
A990 racer
Code points to mass air flow sensor or a bad connector.
Old 07-30-2009, 07:33 PM
any idea what connector it might be? I already replaced the mass airflow sensor and it still dies.
Old 07-30-2009, 07:34 PM
I definitely appreciate your help.
Old 07-31-2009, 06:53 AM
big white bufflo big white bufflo is offline
check and make sure you did not bend any pins on the connectors
Old 07-31-2009, 12:14 PM
A990 racer
Also has the pcv valve been replaced recently and as a side note there are some reman maf's that have been troublesome.
