Old 07-30-2009, 01:17 PM
Batman82 Batman82 is offline
Removing steering column cover
I was trying to remove the steering column cover last night to replace a bad turn signal switch and I could not get the top section to come off. The bottom came off fine after removing the screws. Am I missing something here?
Old 07-30-2009, 01:20 PM
Nick07 Nick07 is offline
Re: Removing steering column cover
Not exactly for sure about Grand Prix's but usually you have to take the steering wheel off to get in there. Check into some more...
Old 07-30-2009, 01:35 PM
Huh, I don't know, I used an archive thread from this forum to troubleshoot it. I was pretty sure they said removing the steering wheel was not needed. If so I might be in trouble, going on a trip saturday morning, checked all over the net for a solution and came up with nothing.
Old 07-30-2009, 01:43 PM
what year is your car?
Old 07-30-2009, 01:50 PM
It is a 2002.
Old 07-30-2009, 02:13 PM
JonJon68 JonJon68 is offline
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
There's a procedure in our "Tips and Maintenance" section on how to remove the top panel of the steering wheel cover. Click on "how to replace your ignition switch" and you'll find directions there.
1997 GPGT 3.8 Dark Teal Metallic. 222000
4 door sedan
No Mods
Old 07-30-2009, 02:28 PM
how bout that... learn more everyday
Thanks!
Old 07-30-2009, 08:40 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Yep, there are two allen screws pointing upward, you have to lay on the floor and break your neck to see them. One is pretty far up there if I remember right.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 07-31-2009, 06:06 AM
BNaylor's Avatar
BNaylor BNaylor is offline
That is very poor advice and a bad assumption.
Timeslip 08/12/06
AF Community Guidelines
Old 07-31-2009, 10:05 AM
doctorhrdware doctorhrdware is offline
What I had done in the past, is to take the seat out so that you can lay down. Much easier on the back and neck, just my worth.
Old 07-31-2009, 01:28 PM
Hey no advice is bad advice, I didn't tell him what to do. I told him what I THOUGHT, I've never had to replace a turn signal switch so I didn't know for sure. Or if there is a way without taking the steering wheel off on ALL cars. Check out http://tss.likeabigdog.com/ and tell this guy he's wrong if you wanna jump down someone's throat about it. No offense, you guys have a lot of good input. I'd just appreciate it if people ask about my source of information before tellin me I have no idea what I'm talkin about. Thanks...
Old 07-31-2009, 02:34 PM
Nick, nobody was jumping down your throat. The great advice "as you mentioned" and the invaluable experience in this forum from our members and moderators is a wonderful online asset and I'm sure that whatever advice was directed your way was not intended to offend you.
4 door sedan
No Mods
Old 07-31-2009, 03:14 PM
tblake's Avatar
In God We Trust
Nick, you have to understand that Bob (bnaylor)'s job on this forum is to keep the information accurate. He meant no offence and did not "jump down your throat". (although that might be sort of funny to see).
BTW, that is a very detailed write up. I am going to book mark it for when my turn signal stock goes bad. Problem with that write up is in fact that it covers all GM W-body's. Which if my memory serves me correctly, the buick w-body needs the steering wheel to come off before the column covers can, the GP does not. Catch my drift? Its sort of like all data, they told me to remove my exhaust down pipe to get the rack and pinion out. I didn't have to do that, but I'm sure their write up covered multiple makes and model cars where some might need certain exhaust components to be removed in order to remove a rack and pinion.
Nuff Said. Keep on posting, but please dont take my feed back (or anyone else's) to heart. I've posted some pretty retarded things in my day and needed to be set on the right path. In Fact Bob and Doc are keeping tallies on my demerit points right now, and I dont have enough to spair before I get the boot.
Old 07-31-2009, 08:30 PM
BNaylor's Avatar
Nothing wrong with the link except it is irrelevant to the '97 - '03 Grand Prix. See below. I would highly recommend reviewing the applicability of what ever link you throw back at me or use as a lame excuse.
This document pertains to the following vehicles:
Generation 1 W-Bodies:
Pontiac
1994-1996 Grand Prix
If you give advice in this forum do so at your own risk if not well researched and we hope what ever you post is beneficial to our membership. If not you may be told it is incorrect or out in left field by a member of the Moderating staff, our Advisors or even a regular member. This is what we do as explained so please don't take it personal or go on a rant.
To the OP:
Here is another good relevant link with pics. For a '97 - '04 Buick Regal but '97 - '03 GP is the same. I have used this same procedure on a Regal and Grand Prix. Note how the steering wheel is left intact.
Click here
Timeslip 08/12/06
