Old 07-30-2009, 08:55 AM
sakana sakana is offline
1999 s10 guessing fuel problem
I believe that i have a problem with either my fuel pump or a clogged fuel filter. Just yesterday i drove down to the gas station and my truck just died, started it up again, and it only ran for a short period of time. I waited for about an hour, than i drove, but it only lasted for about 5 minutes. What do u think?
Old 07-30-2009, 09:34 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1999 s10 guessing fuel problem
Is it losing spark or fuel pressure when it quits?
What is fuel pressure when it running and when it quits?
MT
Old 07-30-2009, 08:43 PM
It's definetely loss of fuel pressure. The car starts up good, than when i put it in drive and press down on the gas, that is when it dies.
Old 07-31-2009, 08:46 AM
MT-2500's Avatar
AF - Advisor
Have you tested for lose of spark or fuel pressure?
Run lose of spark test.
Run the fuel pressure test.
4.3 V6?
The only true test on a fuel pump is to check the direct fuel pressure from fuel pump.
A quick test is to block off the return line and see if fuel pressure comes up to 75-85 lbs.
But do not run the pump at full pressure very long.
Also when testing fuel pump and pressure you need to tape a gauge to outside windshield or outside mirror and drive it on the road for 20 -30 minutes
until the pump gets has run a while to check for a pump fading out after hot.
Hard to start cold or hot and fuel pressure testing guide lines.
Check cold start fuel pressure.
Check engine running fuel pressure.
Check engine running on the road fuel pressure.
Then shut it off and watch for fast leak down.
Pinch off at rubber part or block off return line and check full pressure.
If pump has full pressure with return line blocked and low pressure without it blocked most usually the fuel pressure regulator is leaking or not holding pressure.
Later V6 and V8 gm engines should have 60-66 fuel pressure.
Cold start should be 64-65 lbs of pressure.
If you do not have full fuel pressure on a cold start the injectors will not squirt fuel.
Do not leave home without it.
Engine running should be 60-66 lbs pressure depending on engine load.
Full pressure with return pinched off should be 75-85 or more.
And if it has a fast leak down after shut off you have a leak in system.
Post back fuel pressure readings.
MT
