Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 07-30-2009, 08:11 AM
jason-1995fbody's Avatar
jason-1995fbody jason-1995fbody is offline
adjusatble cam gear
so just curiosity if you install an adjustable cam gear and adjust it, it will set a p1390 code? if so how do you get around this
1989 camaro iroc 350 bored .060 over aluminum intake q-jet unknown big cam 194/150 valves ported and polished automatic /shift kit
93 accord 4 door auto stock
Old 07-30-2009, 08:00 PM
RahX RahX is offline
Re: adjusatble cam gear
Are you messing with a stock engine?
Old 07-31-2009, 07:56 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
You won't get any codes with the adjustable cam gear.
2003 Dodge SRT-4
Old 08-04-2009, 01:22 PM
yeah sort of
Old 08-05-2009, 10:14 AM
HPNOTIQracing HPNOTIQracing is offline
he means stock cam. no need for a gear on a stock cam.
no codes will show.
Old 08-05-2009, 03:47 PM
thats just it thou p1390 is crank / cam not in sequence nad thats the code i get
Old 08-06-2009, 10:39 AM
so you just replaced the gear and now you have a code? is it running any different
also i know your getting a p1390. but do the keydance and see what the code number is
Old 08-07-2009, 01:32 PM
cars not here right now but yeah its got a bit more low end power (almost broke the tires loose with an auto)
Old 08-07-2009, 01:37 PM
i ment is it running like it has a problem. if your crank and cam were not sequenced i would think it wouldnt be running properly.
Old 08-07-2009, 07:18 PM
nope like i said runs good
Old 08-09-2009, 10:19 AM
reset the com and see if the cell comes back on
