Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 07-29-2009, 08:04 PM
champ200 champ200 is offline
Angry 94, 3.1L olds cutlass Supreme
Cranks but wont start. All coil packs have blue spark, 42 psi fuel pressure while cranking, ignition module tested fine at parts store. Crank sensor , fuel filter and fuel pump have been replaced. Checked EGR vale, seems to be working fine. Tried a known good ECM and sill no go. Any suggestons?
Old 07-30-2009, 08:02 AM
thisnametooktolong thisnametooktolong is offline
Re: 94, 3.1L olds cutlass Supreme
The fact that you have spark suggests that the crank/cam sensors are working. About the only other things you need to check with a noid light is power to the injectors, and then there is the MAF sensor. U can also check your TPS because if it has some sort of voltage that indicates that the Throttle is more than ¾ open it will shut off the injectors so that the driver can clear a flooded engine. When cranking I believe that the MAF should read about 3-6 grams per secon
Old 07-30-2009, 04:15 PM
I'll check those and post back my findings. Thanks!
Old 08-03-2009, 09:29 PM
Pulled the upper intake and checked for injector pulse with a noid light and they tested fine. Also, tested the MAF sensor with a know good one and still won't start. Help!
