oil light comes on when stopped, low idle
my oil light comes on when I stop and idle is 800-900 rpms. Any idea what causes this? is it possibly bad IAC valve? 2000 Lincoln LS V6
Re: oil light comes on when stopped, low idle
Have you checked the oil level?
-Rod |
yes, oil level is normal, no loss of oil
It's not the IAC. 750 RPM to 900 RPM is in the normal idle range.
You either have a bad oil pressure switch, or you have low oil pressure. If you have low oil pressure, you are doing damage to your engine. You should have the car towed to a garage that can put a mechanical oil pressure gauge on the engine and determine if the pressure is really low. |
On the V8, it's by the oil filter. I assume it is the same for the V6.
