Old 07-29-2009, 03:45 PM
597GTP 597GTP is offline
Pontiac/Oldsmobile 3.8 engine
Hey, guys im doing my fathers LIM gasket, on his 98 oldsmobile which has the 3.8 engine and when I opened the the gasket set box, there was 3 o-rings with it! Where do they go?
Also I see theres only one plastic elbow to be replaced, is that right? and where do I get this elbow from? zzp doesnt stock or sell just 1 elbow.
thanks
Old 07-29-2009, 04:19 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
Re: Pontiac/Oldsmobile 3.8 engine
thanks
2 O rings are for the coolant elbow...and on the 97 and 98's there is another O ring underneath the elbow. the 99 and up were "revised" with another elbow
the elbow can be found at pretty much any parts store. advanced auto parts has the elbow (part#47065) for $3.28.
Old 07-29-2009, 05:33 PM
So if I buy the new elbow, the elbow does not come with o-rings?
Since they came with the gasket set?
Old 07-29-2009, 07:58 PM
Also on this oldsmobile , Im having a hard time getting the lower intake manifold off. Does anybody know how many screws hold this thing down?
I got , I believe 10 bolts off.
Old 07-30-2009, 12:11 AM
wlkjr's Avatar
wlkjr wlkjr is offline
As I recall, there are only 10 bolts and after 10 years it's stuck pretty good. Some muscle power or maybe a tap with a rubber mallet will help. Be sure to use the correct torque values when reinstalling.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 07-30-2009, 07:35 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
the aftermarket versions of the plastic elbow(s) come with the o-rings and they normally contain both upper and lower for the newer engines, but the upper is the same for both older and newer and still cheaper than buying the OEM at the dealer.
Wally is correct on the LIM, sometimes they have to be convinced with a soft faced hammer or careful use of a pry bar.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 07-30-2009, 05:50 PM
ok, thanks guys for the info!
I will try to get it off very carefully.
Old 07-30-2009, 08:42 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Small soft hammer, or sometimes I've used a screwdrive inside one of the bolt holes and worked it back and forth. The silicone sometimes glues them down.
Don't forget about the EGR stove pipe.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 08-04-2009, 04:36 PM
Hey guys another quick question, what are the torque specs for the water pump on the 98 3.8 oldsmobile intrigue?
Old 08-05-2009, 12:18 AM
wlkjr's Avatar
I just did mine last week but didn't use a torque wrench. I just snugged the bolts down real good and went through them a couple of times. I dont' think it's that critical on the waterpump.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 08-05-2009, 04:32 PM
tblake's Avatar
In God We Trust
Maybe that is the source for your leak wally! (LOL)
Old 08-05-2009, 11:40 PM
wlkjr's Avatar
So what are the torque specs OH GREAT ONE! he he
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 08-06-2009, 09:08 AM
tblake's Avatar
In God We Trust
Sorry Wally!, I couldn't resist!
The torque specs on the 3800 II waterpump bolts are 11 ft/lbs, and an additional 80 degrees.
Old 08-06-2009, 07:56 PM
LOL ok, guys I have another dilemma,
On the Upper Intake Gasket L36 model, what is that lil tube/pipe that clips on the middle of the gasket itself? Cause I bought the felpro set and it doesnt come with it! Or where can I get it from?
Help
