Old 07-29-2009, 04:22 PM
guiwee's Avatar
guiwee guiwee is offline
P/e ?
Quick question for you model heads I have sms focus p/e set.
I want to use the dash and add buttons and such.How do I
drill through the p/e? My pin vise will just scratch it up. My
dremel is too fast even at lowest setting.
Help.... Im curious to hear what you guys do
Old 07-29-2009, 05:05 PM
racer93's Avatar
racer93 racer93 is offline
Re: P/e ?
I'd just drill into the existing dash and add the buttons that way.
Daniel
PS--Did you get my PM from the other day?
Old 07-29-2009, 05:26 PM
sam01contact's Avatar
sam01contact sam01contact is offline
Re: P/e ?
If you need to drill through the PE part, put a piece of Tamiya Masking Tape over it, and mark the spots where you need the holes. Drill the holes placing the PE in a cutting mat, using a hand vise with a fine drill.
The tape will protect the part and help the drill to stay in place while you do the holes.
Works for me!
Old 07-29-2009, 07:02 PM
prortiz80's Avatar
prortiz80 prortiz80 is offline
Send a message via AIM to prortiz80 Send a message via Yahoo to prortiz80 Send a message via Skype™ to prortiz80
Re: P/e ?
good question .......great advise...SAM01
http://s1.bite-fight.us/c.php?uid=55804 opcorn:
Old 07-29-2009, 08:10 PM
MidMazar's Avatar
MidMazar MidMazar is offline
Re: P/e ?
I forgot the specific name of the tool, its i think a set? Looks like the thing that breaks your car windows when trapped in water or when your stealing systems.
Sorry that was off topic, but what you can try is use a really small nail and bang it with a hammer or something, not too hard. Lighty first then see if mark was made, if not bang a little harder. Once you have a indent from the nail proceed to use your drill vise, won't slip now. Just a thought.
In Progress
Old 07-29-2009, 10:07 PM
Slash.Snakepit's Avatar
Slash.Snakepit Slash.Snakepit is offline
Re: P/e ?
Punch and die set ?
"There´s light at the end of the tunnel...it is the train coming towards you..." - Murphy´s Law
Old 07-30-2009, 07:52 AM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
Re: P/e ?
Most PE are Ni-Cu-Zn Alloy, called also German Silver or Alpacca: it's not hard material and you'll easily drill with a good steel/carbon bit: just the bit needs a "mate dot" to not to slip (just do the mate hole with a sharp punch).
Some other PE sets are brass or even Steel: brass is not so hard (but worst than Alpacca to be drilled) but Steel is hard...
gio
Old 07-30-2009, 09:11 AM
CrateCruncher's Avatar
CrateCruncher CrateCruncher is offline
Re: P/e ?
I use a sharp straight pin to make the "starter mark" or "mate dot" Gio mentioned. I press the pin into the metal sheet supported by a hard surface so the pin won't distort the part when I press down hard. You can make a handy tool by drilling a hole ( usually 0.5 mm) in the end of a chunk of sprue and sliding the shaft of the pin in. It's much easier on the fingers if you think you'll be using it a lot.
