Old 07-29-2009, 03:02 PM
zombe1961 zombe1961 is offline
AC/Issue
My 2002 dies when you turn on the air. You can hear the engine come under load then the idle starts cutting out and it dies. Turn off the air and it is fine.
HELP!
Old 07-29-2009, 07:50 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: AC/Issue
Try disconnecting the AC clutch wire then turn the AC switch on to determine whether it's a mechanical or electrical problem.
Old 08-01-2009, 08:51 PM
Re: AC/Issue
The idle seems a little low and when I turn on the ac it just stalls the car. Is there a sensor the controls idle? Could a PCV Valve cause this.
I don't think it is the AC Clutch.
Old 08-02-2009, 07:38 AM
AF - Advisor
Re: AC/Issue
If the AC will stall the engine because of a stuck idle air control valve (IAC) then putting the trans in any gear should stall the engine too.
Old 08-02-2009, 11:25 AM
Re: AC/Issue
The compresser is putting out cold air. and the pully is turning. I am at a complete loss
Old 08-03-2009, 08:06 AM
AF - Advisor
Re: AC/Issue
Does the engine stall when you put the transmission in Drive or Reverse with the air conditioner OFF?
Old 08-03-2009, 08:21 AM
Re: AC/Issue
No it runs fine w/the air off.. If I am on the freeway I can turn the airon and car is fine. Pull up to alight low rpm it dies .
Old 08-03-2009, 08:54 AM
AF - Advisor
Re: AC/Issue
Sorry, I can't find any pics. Is there a device mounted on the throttle body that has a wire or wires going to it?
Old 08-03-2009, 09:54 AM
Re: AC/Issue
There is a plastic cover on the drivers side cover right on top is a sensor or something with a plug. Do you know where we could get a picture.
Old 08-03-2009, 12:09 PM
Re: AC/Issue
Yes it is right on the top by that plastic cover.
Old 08-04-2009, 07:14 AM
AF - Advisor
Re: AC/Issue
Wow, really hate to mess anything up. Besides getting a manual for your '02 at the local parts store, maybe a Pro will see this and respond.
Old 08-04-2009, 10:02 AM
Re: AC/Issue
What is the sensor called can GM help? Is it easy to change?
Old 08-05-2009, 06:37 AM
AF - Advisor
Re: AC/Issue
On earlier engines they were called an Idle Air Control valve (IAC).
Old 08-05-2009, 09:33 AM
Re: AC/Issue
GM says you have to peplace the entire throttle body. It is not servicable.
Any ideas?
Old 08-09-2009, 03:35 PM
Re: AC/Issue
Could it be the MAP sensor?
