Old 07-29-2009, 01:36 PM
kbaird83 kbaird83 is offline
shocks
im looking to put some new front shocks on my 02 silverado 2wd. i looking for something under 40-50 bucks per side. i would like to find something a little stiffer with better handling esp. at highway speeds. any suggestions? also im using spring rubbers to increase the stiffness on the coils. any one used these before?
Old 07-29-2009, 09:13 PM
Re: shocks
also just read a post about the intermediant steer shaft. my truck clunks at low speeds while turning. also feel it at higher speeds while turning and hitting bumps but dont hear it. tends to get a little jumpy on larger bumps on highway just feels a little loose over high speed bumps? does this sound like that shaft needs to be replaced? this is the whole reason i was redoing the suspension was because i thought that was where the clunking was comming from. is this a danger over time?
Old 07-31-2009, 01:02 AM
bigbadram51 bigbadram51 is offline
Re: shocks
I ran the Bilstein 5125 before I upgraded to dual Fox resi shocks... The bilsteins were great shocks
2004 Silverado Half-Ton Crew
7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block
3" PA Body Lift
Yukon 4.88's with Auburn LSD
Xentec 6500k HID lows, Silverstar Ultra brights
Wade in channel window vents
Covermaster Top
Flowmaster 40 series, dual outs
Nelson 89/91 HOT TUNE
20" MB Gunner 6's, 37" Toyo Open Country MT's
Eclipse AVN6600 w/sirius and IPOD controllers
Code Alarm w/ Remote Start
Old 07-31-2009, 10:31 AM
j cAT j cAT is offline
Re: shocks
I got my bilstiens at the shockwarehouse ...good price...lifetime warr....all MY vehicles have these bilsteins good ride....
for off roading etc....you may require something different..
Old 07-31-2009, 01:25 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: shocks
For the clunking, check your front sway bar end connections, bushings, and frame connections. A crushed or missing bushing will cause that clunking when the body leans during the turn.
I'll second the Bilsteins, though I have been looking at the Rancho shocks too...RS9000XL has 9-way adjustability but they're ~$75-100 each. The no-frills RS5000 are in the price range you're looking at.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 07-31-2009, 02:08 PM
Re: shocks
Originally Posted by j cAT View Post
I got my bilstiens at the shockwarehouse ...good price...lifetime warr....all vehicles have these bilsteins good ride....
The 5125 is a great all around shock, even for off-roading... A ton of lifted trucks run this shock
3" PA Body Lift
Covermaster Top
