Old 07-28-2009, 01:22 PM
Jerry99 Jerry99 is offline
P0171 too lean bank 1
Hello I am trying to find out if I have a bad o2 sensor
any help on this would be great
1999 Z24 Conv 2.4 aem short air induction
Old 07-28-2009, 02:15 PM
thisnametooktolong thisnametooktolong is offline
Re: P0171 too lean bank 1
Probably not with a 171.
You can check it out with a scanner. The lean condition is usually caused by a few things. Low fuel pressure, plugged up injector, Intake leak? A good hole in just the right place in the exhaust., and a bad Hego. That thing is an OBD II so you can graph the Hego. If it is switching but not going above (around .5 or .6 volts) it could be a quad driver or the wires/ plug and of course the hego itself. This one takes a mind to actually make a diagnosis. Without the hands on I refuse to guess
Sorry this is not a sit at the computer and just guess kind of thing
Old 08-06-2009, 01:21 PM
JerryZ24 JerryZ24 is offline
It was the fuel pump
and boy was it pricey
