Old 07-28-2009, 11:59 AM
GARY BRUNGARD GARY BRUNGARD is offline
No driving rear tail lights?
Hey everyone, I have this problem that I dont have any running lights at the back of my 98 K1500 Silverado also no liscense plate light either.I did check the fuses and the ground and found that they were good. The front works just fine and I do have brake lights and directionals. Any suggestions would be great, thanks.
Old 07-29-2009, 05:49 AM
Jeremy-WI Jeremy-WI is offline
Re: No driving rear tail lights?
You should check the connectors and maybe put some dielectric grease on the pins. There are connectors at both taillamp assemblies and one more near the spare tire
Old 07-29-2009, 03:56 PM
All the connections at the back are good but what I didnt do yet was to test for power at the plug by the spare tire. Have just been to busy with work,thanks for the reply.
Old 07-31-2009, 11:06 AM
Still have not got to the lights yet been to busy working but noticed now my gas needle guage is vibrating back and forth very quickley in a small distance.
Starting to wonder if there is more to the eletrical failure than I think.
Old 07-31-2009, 12:18 PM
Well guys found the light problem, it was at the trailer accessory hook up. One of the stackons had just disintergrated from the inside out so replaced it and covered it up with 3m liquid electrical tape works good as new!
Old 08-02-2009, 08:01 AM
j cAT j cAT is offline
If you ever correct the vibrating gas guage indicator needle ,, please post how this issue was corrected ..
Old 08-05-2009, 10:42 AM
Sure thing, as of now have not looked into it yet but when I do I will reply what was up.
Old 08-05-2009, 03:29 PM
thanks,,,on this issue most seem to just accept it,,,,others report the dash cluster was bad ,,,but what? why?..
