Old 04-03-2003, 12:02 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Should I buy this stuff?
Okay... I've got a chunk of money, and I'm making a list of things to buy for my car/engine, but there are a few items I have a question about...
Mainly a fuel rail... Do I need a fuel rail? Or would I only need it if I went turbo or NOS? It's just going to be a D16Y8 N/A engine, and possibly built internals (crankshaft, pistons, rods, cams, etc.)
What about an aftermarket Fuel Pressure Regulator? Would it really matter or be worthwhile?
What about injectors? Should I just use the OEM ones?
What kind of internals should I get for crankshaft, pistons, rods, cams... I'm not planning to raise or lower the compression at all (or should I?), just looking to replace the internals with high quality lightweight parts...
Just FYI, other things on the list are:
Corbeau Seats (probably order them today)
3 point harnesses
Stereo stuff (2 amps, seperates, and head-unit)
Throttle body (need a replacement because the TPS sensor busted on mine)
Lightweight Pulleys
Injectors
Lightened Flywheel
Old 04-03-2003, 12:07 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Its always a good idea to upgrade ur fuel especially if ur building performance. If you gonna N/A just go high compression.
Old 04-03-2003, 12:14 PM
91civicDXdude's Avatar
from the mouths of 10 second honda drag racers:
upgrading the fuel rail isnt necessary unless you're pushing over 300 horsepower or so. The same goes for the injectors. You needent upgrade them unless you are going forced induction. The same goes for the iginition system. The factory honda ignition will support up to 350horsepower or so.
If you want power, get a stage 2 or 3 cam, upgraded valve train, thinner head gasket, bigger bore throttle body, and possibly a slightly ported and Poilished head. to put that power to the ground better, get a lightened flywheel (not too light, only shave a couple pounds off the stock one, having too light of a flywheel will make you lose power when you shift or go up hills, you need some rotational mass to keep the engine going), light weight wheels, and an upgraded clutch.
I've also heard that using light weight pulleys will throw off the crankshaft balance a slight bit, leading to your number 1 crank bearing to go to shit.
Again, this is just what i have heard from honda people who run 10 seconds with d series engines.
Old 04-03-2003, 01:25 PM
ci5ic's Avatar
Thanks for the info....
So I shouldn't bother with the internals like the crankshaft/pistons, etc?
And what/where to get upgraded valvetrain?
Old 04-03-2003, 02:35 PM
Jay eS Iye's Avatar
Jay eS Iye Jay eS Iye is offline
Send a message via AIM to Jay eS Iye
hey what is N/A?
The Civic is gone...
The Camry never ran...
The Chevy is here to stay...
The Ultimate Honda Engine
Old 04-03-2003, 02:37 PM
GTA's Avatar
GTA GTA is offline
Whee..
Originally posted by Jay eS Iye
hey what is N/A?
naturally aspirated. basicly no forced induction (supercharger, turbo, ).
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 04-03-2003, 03:05 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
The stock fuel system is better than what most people think, if anything in the fuel department get a FPR (fuel pressure regulator) and than i would just build-up the valvetrain. The bottom ends are pretty strong, but the valves will float at like 7000-72000 RPM, no point in having an upgraded valvetrain though if you can't rev high enough to use it so than you need a new ECU or have one chipped. So many ways to look at this.
Old 04-03-2003, 03:31 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
I went N/A in the d series im building, i got 10.5:1 pistons, shot peened the stock rods, ARP rod bolts, polished the crank and a aluminum crank pulley for internals.....im getting a adj. FPR and allready have a fuel rail....simply because im building the motor now and have the time to replace anything i want before i swap it in....
gunnmen01
My other ride..... is YOUR MOM !!!!!!
