Old 07-27-2009, 02:13 PM
modlman17's Avatar
modlman17 modlman17 is offline
Tamiya AMG Mercedes C-Class DTM D2
Here is my latest build. Tamiya kit built box stock. Paint is also Tamiya. The build went together really well. I had a few issues with the decals which dissapoints me. I love these big decal jobs and usually have few problems with them. However, this time I had to experiment with different setting solutions and couldn't really find a happy medium. My trusty Walters Solvaset was too strong and Microscale Microsol and Microset wasn't quite strong enough. I should have tried my Badger solution or maybe some mild heat. That may have been just right.
Rob
The Following User Says Thank You to modlman17 For This Useful Post:
UltimateGTR (10-13-2011)
Old 07-27-2009, 08:13 PM
rollover's Avatar
rollover rollover is offline
Re: Tamiya AMG Mercedes C-Class DTM D2
It looks great to me, hard to see any flaws in the decals.
Jeff Grebe, Plasticrastinator
Not finishing kits, My specialty
Old 07-29-2009, 08:17 PM
modlman17's Avatar
Thanks for the comment Rollover. You have to look close but there are a few places that I am not completley happy with. Then again, I'm a bit of a stickler on my decalwork.
Rob
Old 07-29-2009, 08:33 PM
MidMazar's Avatar
MidMazar MidMazar is offline
Looks like a nice build.
As far as decals, mild heat works great. Hair dryer, and a hot water cloth works really well for me. With the wet cloth what i do is soak a piece of it in running hot water then squeeze it so most of the water drains, but is still damp. Then run it across the decal while holding it in place. I actually sometimes like it more than decal solvent because some old decals get ruined by them, and or leave spots sometimes.
In Progress
Old 07-30-2009, 08:17 PM
modlman17's Avatar
Thanks for the tip on the warm towel. I hadn't heard of that one. I will try it as well as pulling the hair dryer out of retirement on my Schnitzer Original Teile BMW CSi build. I'm hesitant to put solvent on 20 + yr old decals and they will definitley need some encouragement.
Rob
Old 07-31-2009, 06:21 AM
HamburgerHead HamburgerHead is offline
Wow, really nice decal work! And the rest of the model looks great as well! Could you tell me how you did the radiator grill? You did a great job on it and I am soon to build a mercedes myself.
Old 07-31-2009, 09:44 PM
modlman17's Avatar
Thanks!
I used the Detailer Black-it-out on the grill. It took a couple of coats to get good coverage and I ended up touching up a couple of places with some Humbrol Matt black and a fine tip brush. After looking at the photos, I see a couple of more places that need touched up. I'll use the same technique on my next Mercedes builds.
Rob
Old 08-01-2009, 09:43 AM
AAlmeida's Avatar
AAlmeida AAlmeida is offline
Very nice, I love DTM cars. Rob, how did you paint the black rubber on front lights lens? How did you mask it? Looks really straight and clean, I have to paint mine too but I can figure out how to do it like you did it. Thank you!
Almeida
Almeida... I'm back!
Old 08-02-2009, 07:39 AM
modlman17's Avatar
Almeida
I love the DTM cars as well. If it wasn't for them, JGTC and Prototypes, my modeling would be over.
As for the black on the lights, I used a fine tip brush and some Humbrol Matt Black paint. It turned out very good. Luckily the borders are well devined and it makes it easy to conform to them. A tip that I alwas use is to paint the edges of the lense as well. It makes them not look quite so thick and adds some uniformity to the lenses. To prevent the paint from marring the surface when I attach them, I use a clear watch makers cement. It makes it a lot less worrisome to attach the lenses, door handles, etc. Hope this helps!
Rob
Old 08-02-2009, 02:44 PM
Mojo_stevo's Avatar
Mojo_stevo Mojo_stevo is offline
I love these older DTM's. Great job!
Old 08-03-2009, 07:28 AM
AAlmeida's Avatar
Originally Posted by modlman17 View Post
As for the black on the lights, I used a fine tip brush and some Humbrol Matt Black paint. It turned out very good. Luckily the borders are well devined and it makes it easy to conform to them. A tip that I alwas use is to paint the edges of the lense as well. It makes them not look quite so thick and adds some uniformity to the lenses. Hope this helps!
Rob
Thank you, I will try that. Almeida
Old 08-03-2009, 07:39 AM
Voljeepx's Avatar
Voljeepx Voljeepx is offline
Rob, it looks great! The decal work is first rate. Great to see another Kentucky boy on the forum!
Old 08-03-2009, 06:13 PM
modlman17's Avatar
Thanks for the comments. Based on the lack of hobby shops in the state, there are just not enough Kentuckians modeling these days.
Rob
Old 08-05-2009, 12:06 PM
gasdriverca's Avatar
gasdriverca gasdriverca is offline
Send a message via Yahoo to gasdriverca
Excellent work!!!!
