Old 07-27-2009, 12:47 PM
ChrisinVT ChrisinVT is offline
*** w-body coil-over upper spring perch ***
*** W-BODY COIL-OVER UPPER SPRING PERCH ***
Look what I made up... Some upper coil over spring perches/mounts! I know there were a bunch of people a while back that were looking for these, and since they don't seem to be made anymore, here these are.
If there's interest, I have the ability to mass-produce these.
As you see, they're similar to the TDC mounts Josh (TurboSedan) from gmwbody.com had on his car, but these were designed a bit differently so they fit snug into the OEM-style strut mount. These have to be hammered into the OEM strut mount with a rubber mallet, or you can set it in there and slam the whole setup against a desk to wedge it in there. It comes out of the strut mount (if needed) with some slight prying from a screwdriver. IMO they should work better this way because they won't be resting on the springs, but we'll see....
www.gmwbody.com
The NEW GM W-Body Forum!
Chevy, Buick, Pontiac, Oldsmobile
Old 07-30-2009, 10:03 AM
Re: *** w-body coil-over upper spring perch ***
No interest in these?
www.gmwbody.com
Old 08-01-2009, 08:29 PM
CrazyHorst CrazyHorst is offline
What's it made out of (material) and how is corrosion prevented...?
1988 Chevy R-30 1 ton DRW pickup (217k)
1991 Chevy S-10 4WD pickup (192k)
2000 Grand Prix GTP (218k)
2002 GMC Yukon (185k)
2009 G8 - GT (46k)
Old 08-01-2009, 08:45 PM
It's made out of aluminum
www.gmwbody.com
