Old 07-27-2009, 08:03 AM
intuned's Avatar
intuned intuned is offline
how much time to do you before polishing?
i just sprayed the last coat of clear on some of my builds and i wanted to know how much time do you wait before you sand it and polish it?
i was using automotive paint before and i was waiting 2 weeks but for those, it's all tamiya sprays. primer, paint and clear.
i sprayed 3 coats of clear btw
thanks guys!
Old 07-27-2009, 08:12 AM
racer93's Avatar
racer93 racer93 is offline
Re: how much time to do you before polishing?
thanks guys!
The way to know if the paint is totally "dry" is when you can't smell the paint anymore. Or, generally with Tamiya rattle cans, a couple of days is plenty.
If you're a "serious" builder, look at a food dehydrator. They can be found for $40 and speed up the drying time incredibly.
Daniel
Old 07-27-2009, 08:14 AM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
I never sand the body after applying the final layer of clear. After the final clear application, I give it a week before polishing.
PHOTOBUCKET SUCKS
Old 07-27-2009, 11:23 AM
drunken monkey's Avatar
Razor Sharp Twit
If in doubt, give it a sniff.
If you can still smell the solvents then give it another day.
If it smells the same the next day, you're probably good to go with the polishing.
This is of course, assuming you didn't lay on a single thick heavy coat.
AF's Guidelines
Read them.
Old 07-27-2009, 05:01 PM
Enilder Enilder is offline
+1. I am new to this but shouldnt you be sanding before painting (definitely before clearcoating). Please correct me if I am wrong.
Old 07-28-2009, 12:01 PM
Didymus Didymus is offline
I wait two or three days before polishing.
If Tamiya Clear (TS13) is sprayed right, it should not require sanding. A "perfect" spray job needs no polishing, or just some Tamiya Fine compound where there's visible paint texture. If there's quite a bit of orange peel because it was sprayed too thick or dry, start with Tamiya Coarse and then Tamiya Fine. For a show-car gloss, finish up with Tamiya Finish.
Ddms
