Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 07-27-2009, 12:06 AM
cshults's Avatar
cshults cshults is offline
Suspension
I have a 2001 Bravada with just under 90K on it and want to replace the struts/shocks.
My question is, what other suspension parts should be replaced at this time to restore an "as new" ride quality?
Chris S.
2001 Bravada Platinum Ed.
1992 Beretta GTZ
Old 07-27-2009, 09:14 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Suspension
I would be more concerned with the integrity of the ball joints than anything else.
Old 07-27-2009, 06:52 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Suspension
Along with the new shocks, new tires or rotation & balance and an alignment check/adjustment with their usual inspection makes mine feel tighter & better.
Old 07-30-2009, 07:21 PM
cshults's Avatar
Re: Suspension
What about springs? Would they be fatigued enough to warrant replacement?
Chris S.
1992 Beretta GTZ
Old 07-31-2009, 06:29 AM
AF - Advisor
Re: Suspension
I wouldn't think they would be fatigued under normal use but if you spend time where the springs would really get worked like rough roads or even off-road, they might be getting soft.
On a very level surface, you might measure the height and compare right front against the left front then compare the right rear against the left rear. I'd be real happy if they didn't vary more than 1/2 inch.
Old 08-05-2009, 10:52 PM
cshults's Avatar
Re: Suspension
Well here's the final tally of suspension compnents to be replaced...
Front sway bar links
Control arm bushings
Upper and lower ball joints
The struts passed the bounce test, so they're gonna stay on for awhile longer until I can get some more $ saved...many more things needed attention...
Chris S.
1992 Beretta GTZ
