Old 07-26-2009, 09:39 PM
duramax04 duramax04 is offline
04 inner axel on front diff
i am rebuilding my front diff in my 04 2500HD because the seals are leaking bad and it was very low on oil once. now when i use the 4 wheel drive i can here bearings making noise. i got the diff out and split and most of the bearing out with no problem. the olny thing i cant get out is the drivers side axel it will not budge. if any one knows how it comes out the information would be greatly heplfull.
Thanks Josh.
Old 07-28-2009, 10:00 AM
jyount jyount is offline
Re: 04 inner axel on front diff
Been a while since I have been into one, but if I remember right, once you take the diff out and split the case, the axle is held into the case by a big nut or something of the like.
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
