Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 07-26-2009, 08:03 PM
redcar redcar is offline
Loose spark plugs
Check engine light came on today on my 03 Impala 3.8 LS, had it scanned and said it was random misfire, no specific cylinder indicated. Checked the wires and plugs and found two plugs very loose. Is this common? Thanks in advance for any advice.
Old 08-08-2009, 09:04 AM
blksuperman409 blksuperman409 is offline
Re: Loose spark plugs
never heard of it. it just wasnt tighen tight enough when it was changed.... just tighten back up and the light should go off after a few days.. or get it reset then it wont come back on...
Old 08-09-2009, 09:13 AM
j cAT j cAT is offline
plugs can loosen,,,,use of a torque wrench is recommended when installing,,,15ft lbs is the usual torque....
sometimes carbon gets on the threads,,,this can give the installer a false sense of sercurity,,,,of tightness..
in the old days excessive pinging will[did] cause this problem...
