Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 07-26-2009, 07:05 PM
Panoz26's Avatar
Panoz26 Panoz26 is offline
LS Engine is on its way
Well, I took the plunge. My new motor will be here on Wednesday.
2004 LS1 w/44K miles.
So, if you know anyone needing a 4.6L Ford Motor - please send them my way - Im willing to make a great deal for someone so I can get it out of the garage.
Hope everyone is well!!
Devin - (aka Panoz26)
Formally WC Car # 26, Red
Now = WC-GT2 # 211, Black
Old 07-27-2009, 06:49 PM
David Eastman David Eastman is offline
Re: LS Engine is on its way
Devin are you going the carbed route like eric or sticking with the FI?
David
Old 07-27-2009, 07:23 PM
Panoz26's Avatar
David
Hey David, I will be going the Carb route. Debating on the Holley or the ProForm.
Old 07-27-2009, 07:28 PM
panozracing's Avatar
panozracing panozracing is offline
i have a spare 650 demon if you want one (it might be a 750 but need to check numbers)?
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 07-28-2009, 07:13 AM
Panoz26's Avatar
Thanks Brian, let me know what you have and how much.
Old 07-28-2009, 08:48 AM
Panoz26's Avatar
OK, here is the ever-aging, always debated question. I have been getting flack from my friends on considering a Carb setup vs EFI.
Since I value the opinion of our members - I pose to you.
Carb - why / why not
EFI - why / why not
__________________________
Old 07-28-2009, 09:28 AM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
Why
  • KISS - Less parts
  • See above - less weight, less complexity, makes more power on the high end, but marginal
Why Not
  • Not as smooth in lower RPM operation
  • Can't optimize itself for atmospheric changes. You can either tune/re-jet it every day or pick a good middle of the road tune like we have.
EFI - why / why not
Why
  • More power under the curve as it is better optimized at every RPM
  • Better low RPM operation
  • Self-adjusts to all weather conditions
Why Not
  • More parts, more complexity, if something goes wrong you have no way to pull engine codes or diagnose.
For our application we went car to just keep it easy... less parts, less weight, etc. The car doesn't need to put around down and have good low speed drivability... it just needs to do good things north of 3000 rpms.
After the BS we went through a few months back I was annoyed w/ it all, but now that it's setup properly I don't regret it at all. For these cars I'm a fan of keeping it simple.
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
Old 07-28-2009, 11:18 AM
PanozDuke PanozDuke is offline
Great reply Brian, really boiled it down to the basic pros and cons. Carbs are basically cheaper IF you are starting from scratch. If Devin is getting the efi , harness and computer with the motor, that turns around.
I have a 302 Mustang (mostly street, some HPDE). I've been playing around with the carborator for a month with a low speed stumble and have had it on and off and apart about six times. It's a DP 650 and I think I might have got most of it ironed out, but it's not perfect. Nature of the beast with the power valve metering it comes with. Started with a blown power valve and I really screwed it up with accelorator pump fiddling thinking it was getting too big a shot. Really got to read up on these and take it step by step. I still think it is jetted too rich for the setup, but that is a whole other story that will take a lot of careful trial and error to get right.
Devin, my thought is to check with Eric (too fast #62) and see how his came out with the carb and if he had any tune issues.
I'm convinced there is no substitute for a good day on a chassis dyno with a carb expert and lots of parts when you are in uncharted waters or you got yourself way out of wack in several areas for carb adjustment. Wish I had access to that where I live. Sure would make primary and secondary jetting easier as well as modifying the DP power valve circuit for driveability.
As an aside, I have pieced together info from several good Holley operation and tuning guides on the net into one document I think is really good, accurate and complete. Much of the advice I found on a number of forums is garbage or not understandable and ofter incomplete or contradictory. Lots of guys (like me) think they know what works based on past experience or info picked up from other graduates of bad experiences. I was and they are wrong in many cases and need a good grounding in how and why these things work and how the adjustments interact.
Anyone wanting a copy, send me a PM with your email. It's about 40 pages with lots of pictures and info that wouldn't apply to every application, but helps a guy understand these rascals before you tear into them doing things that just make things worse. Much of it would apply to the Holley based variants such a Demon, ProForm, etc.
Mike
Old 07-28-2009, 11:23 AM
Cobra4B's Avatar
Yeah for tuning we had it at Performance Autospot on their dyno w/ their "carb guy" doing it all.
Brian B.
Old 07-28-2009, 02:58 PM
Panoz26's Avatar
great input. Thanks!!!!
Eric and I garage mates.... :o)
Old 07-28-2009, 05:40 PM
Cobra4B's Avatar
FYI you can get a conversion kit to use a real distributor w/ the LSX vs. the way Eric did it. I have no experience w/ it but I know it exists.
Old 07-29-2009, 11:04 AM
Panoz26's Avatar
http://dcazin.c4-motorsports.com/LS1Engine/
Thar she blows
Old 07-29-2009, 12:13 PM
Cobra4B's Avatar
What'd that come out of... the PS setup and alternator location isn't Corvette. GTO?
Old 07-29-2009, 12:14 PM
Panoz26's Avatar
yep. GTO. was wondering if anyone would catch that.
Old 07-29-2009, 12:26 PM
Gatorac's Avatar
Gatorac Gatorac is offline
That power steering setup looks like it may work. That would be a plus.
They make so
e slick dry sump set ups for the ls motor that has the pump attached to the pan so you don't need scavange lines.
Have Fun
Jim Pomroy
96 Miata track car.
2012 Camaro SS.
Backdraft Racing Cobra #930
92 Miata "LemonDrop"
Saturn V Rocket Miata Crapcan #81
99 Miata daily driver.
