Old 07-26-2009, 04:53 PM
bthrmbndts bthrmbndts is offline
tansmision issue
98 gmc blazer: shifts from first to sec. with no prob. at about 25mph it revs. high to about 3000 to 3500 rpms before shifting to third sometimes it doesn't even feel as if it shifts to third. just changed trans. filter and gasket, was told could be clutch.. please any advise would help?1
Old 07-27-2009, 08:38 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: tansmision issue
If a standard transmission.
A weak clutch/pressure plate lets engine race up in higher gears.
Going down the road Put it in 4 or od and if engine races up you need a new clutch kit.
If a auto matic transmission get it on a engine/transmission capable scanner and see what is going on.
Any check engine lights on?
Make sure fluid level is good engine hot in park.
Make sure filter is the right one and on good.
Was there any metal or clutch in bottom of pan?
Does reverse slip or hold good?
If any codes post back codes.
MT
Old 07-27-2009, 06:27 PM
automatic.fluuid is good hot in park, and reverse holds good, pan was clean , just dark fluid and filter black . picked up new filter from shop looks same , have friend that has dio. machine will hook it up next day or so.. what about idle air control or
?IAC
Old 07-27-2009, 07:13 PM
MT-2500's Avatar
AF - Advisor
?IAC
You need a transnmission capable scanner.
MT
Old 07-27-2009, 10:14 PM
will get capabal scanner as soon as i can. Thank You for your help.
Old 07-28-2009, 07:52 AM
MT-2500's Avatar
AF - Advisor
You are welcome.
Read out all transmission slipage and shifting data.
Post back any codes.
Engine or transmission.
Was the transmission you took out doing the same thing or what was it doing?
MT
