Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 07-26-2009, 03:43 PM
tempfixit tempfixit is offline
91 coralla power window problems
None of the power windows work ar all now, passenger front window down. I do not have any power at the black wires at the master switch. Acutally the only power I have at this time is the power door locks. Is there a relay somewhere I am missing??
Any tips would be appreciated.
Thanks
Old 07-26-2009, 08:25 PM
roadrunner2 roadrunner2 is offline
Re: 91 coralla power window problems
Thanks
Check all the fuses until you find the one associated with the power windows.
You MAY have a bad switch.
If the fuse is good, use a continuity tester and check for power in the wiring that goes through the protective sleeve between the door and the door post.
Wiring here tends to get brittle with age and the constant door opening/closing breaks the wires. (inside the insulation)
The problem with doing nothing is not knowing when you're finished.
Old 07-27-2009, 08:35 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
I'll second the wiring harness. Sometimes you can get intermittent contact to verify breakage by pinching and rolling the rubber sleeve in between your fingers while working the switch. Try different door positions too while doing this.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
