Problem with Passlock?
Strange thing occured this morning. My 99 Suburban 1500 2wd 130,000 miles would not start. It would turn over but it sounded as though it was starved for fuel. It eventually started but then I noticed that the word "SECURITY" was lit constant on my dash and I read up on it in my manual. If it is faulting I would like to pull the fuse, but the manual says it shares a fuse with steering. My mechanic pulled out the steering sensor about a year ago because the steering wheel would turn sharply in a curve for no reason. Do you think the reason my truck would not start is because of Passlock? I have not done a fuel pressure test and the fuel filter was replaced almost 2 years ago. Thanks for your help.
Re: Problem with Passlock?
I have passlock problems with my Impala. I dont think your passlock it the problem though. When the passlock fouls up you wont be able to turn it over at all.
I realize this is going to sound crazy and too easy, however I got the idea from my son who repairs his own electric guitars. I sprayed WD-40 on my key and inserted it into the ignition the truck started with no problem and has been for several days now. When before it was not starting about every 5 cranks. I was having to leave the key on and let it sit for 10 minutes. My key does not have the chip on the outside. I figure if nothing else I bought myself some time. Good luck I hope it works for you.
10 hours away from John Deere master certified also master certified ASE tech. Exp. in both. Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training Gave up wrenching for "Greener Pastures" Current job: RN 2010 Silverado Z71 5.3L 65xxx Wife's 2007 Suburban 1500 LTZ 5.3L 102xxx |
