Old 07-26-2009, 10:40 AM
george2002 george2002 is offline
Low beam headlights not working
Help!!!!!!! I can't get my low beam lights or turnsignals to work. All the fuses under the hood are good, just checked them. The high beams work, the momentary high beam flasher works. The emergency flashers do not work. The parking lights come on.
97 F150 XLT, 4.6, 2wd, extended cab
Could this possibly be the MFS on the steering column or the headlight switch on the dash. Pulling my hair out down here, sitting here looking at the lake, stuck here with this headlight problem.
Thanks,
George
Old 07-26-2009, 10:52 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Low beam headlights not working
If all the fuses are indeed good, I would replace the MFS. The indication there is the 4 ways do not work. The MFS is the only place the lights have in common.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 07-27-2009, 12:50 PM
NOW WHAT? I checked all the fuses on the outside box, all are good. Started to check the fuses in the cabin box, pulled a couple out, looked good, went to crank the truck-----will not turn over. Full power, windows work, horn works, lights work, but no power to the ignition. Everything works when switch is in the accessory position. I replaced the 2 relays that are in the cabin box, upper left hand corner of the fuse box. Any suggestions?
