Old 07-25-2009, 10:01 PM
ukrkoz's Avatar
ukrkoz ukrkoz is offline
Eird oil leak
i have oil leak that i can't figure out:
black marker does not work well, but you can see where oil collects eventually. also, it's deeper into the corner, where they came up with a flange for camshaft sprocket.
so, gasket is brand new, maybe 500 miles on it. all bolts are TIGHT.
i clean it once a week, it comes back.
say, remove the cover and re-seal with red slicone?
Old 07-26-2009, 12:51 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: Eird oil leak
The only places you are supposed to use silicone is in the corners where it archs.
Check your Oil cap, they have a bad tendency to leak
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 07-26-2009, 03:26 PM
ukrkoz's Avatar
Re: Eird oil leak
oil cap's on the opposite side.
i have no idea. unless oil just creeps up the valve cover along that black enamel.
totally weird.
