2005 Suburban
I have 2 separate issues here with my 2005 Suburban LS , it has 103,000 miles on it and I have been gitting the engine light that point to the lt bank O2 sensors. I have replace both already and the code keeps coming back. The only other option I have at this point is the catalyc convertor. Has anyone else had this issue with a easier fix. The cheapist I could find was just over $300 dollar for the unit. The second issue is a cd is stuck in the player. It is a single unit in the dash. It has been replaced once under warr. with the same issue. Any help on either issue would be helpful.
Re: 2005 Suburban
who is the CD manufacturer [name of company that made disc] ? |
Re: 2005 Suburban
The code is P0420. and as far as the manufacturer of the CD player in a 2005 suburban I am not sure.
Re: 2005 Suburban
In cases such as this, I swap the downstream sensors, then see if the DTC changes,,,if it does this means the sensor is bad...if not your cat converter is bad,,,,at this mileage it would be odd that the one cat converter is bad...unless this engine had some poor maintenance over its life... bad plugs,wires,dirty MAF,modifications ,intake manifold/coolant leaks into the combustion chamber,, etc..... On the CD issue,,,my question is what is the DISC manufacturer name,,,,not the player manufacturer... in other words ,,,is this a cd you made ???? some disc's made where too thick,,,this was several years ago...causing your exact problem.... the repair center just removed the stuck cd...I'm sure parts were not replaced/or the player.. |
Re: 2005 Suburban
I have put two new sensors on the upper Lt bank and swapped the lower ones from side to side. The code stayed the same. It did not swap sides like I hoped it would. The vehicle has had regular oil changes along with all other scheduled maint. New plugs and wires. No oil consumption and no vaccum leaks to be found. Engine runs fine with no misses or anything like that. I just thought it was odd to have a cat. go out like that. As far as the cd maufacturer goes it is a store bought cd. The wife said it is her Sugarland cd. Also the unit was changed last time under warranty. The last cd was my Overflow cd that was purchased from the store. Neither was made at home.
Re: 2005 Suburban
Double check the wires to that driver's side post-cat sensor (three wires: 12V power, ground, and signal) and if good, swap the new pre-cat sensor with the suspect post-cat sensors on that side and clear the codes. If the trouble code reappears and is still the same, it's definitely the cat.
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. Last edited by jdmccright; 07-27-2009 at 10:27 AM. Reason: clarification & grammar |
Re: 2005 Suburban
with an aftermarket player anything is possible,,,,usually you can force eject the cd ,,,check with manufacturer how to do this.. |
