Old 07-25-2009, 05:14 PM
88Porsche944 88Porsche944 is offline
Paint problem
I've got a Camaro, that is yellow plastic, I've primed it with Tamiya gray primer, then white primer. The ultimate finish color is to be semi gloss white.
The white primer is turning a slight yellow(ish) color. It's not been in the sun. It has been in the box. Any ideas why I've got this yellowing going on and how to keep it from turning yellow once the finish coat(s) of paint are on?
Search was used however, all I could come up with is "yellowing decals".
Thanks.
Trevor
Old 07-25-2009, 05:58 PM
CFarias's Avatar
CFarias CFarias is offline
Re: Paint problem
It is most likely the yellow color of the plastic bleeding thru the primers. This is a common problem, particularly with high contrasting colors placed on top of one another and something that should always be concern when painting white.
Try using a primer-sealer. These are design to prevent this from happening. It is not the same as primer but many of these primer-sealers are safe enough for plastic.
I use the Dupli-Color Paint Shop Pro system. It has a very dark gray primer-sealer but I've had no problems painting white on top of it.
Old 07-25-2009, 06:18 PM
guiwee's Avatar
guiwee guiwee is offline
Re: Paint problem
What he said!!!
Old 07-28-2009, 09:47 PM
Doc305's Avatar
Doc305 Doc305 is offline
Re: Paint problem
I never had that problem even in similar situations. Try that primer-sealer stuff. I, in ur situation, would just sand the entire body very good w/ 600grit and apply primer as usual. Good luck man.
Old 07-28-2009, 10:48 PM
Enilder Enilder is offline
Re: Paint problem
can this be done with thicker (extra layers) of white primer? i am guessing that you have very shallow primer layer...i've yet to try any light colors but i was just wondering.
Old 07-29-2009, 12:40 AM
Re: Paint problem
Problem solved. I used flat black, then Tamiya primer. Now, I just have to get some time to complete it..
I've been asked by a co-worker to build a scale model of his 1:1 car. 2004 Corvette C5 Z06.
However, moving into the new apartment must come first.
Old 07-29-2009, 12:58 AM
white97ex's Avatar
white97ex white97ex is offline
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
Re: Paint problem
I find it kind of funny you should post this. I've been going through my old builds, sorting things, and trying to finish up the 18 million model projects I have going. I think I found parts for 3 or 4 different c5 Z06's. Glad you got the problem solved.
My name is Russell, feel free to use it.
I'd rather be hated for Who I Am than be loved for Who I Am Not
