Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 07-25-2009, 04:31 PM
jima4624pY2 jima4624pY2 is offline
Talking air bag light
i have a 1993 towncar and the air bag light is flashing 5-1 i know it's a code but i can't seem to find what code it is can somebody point me in the right direction or what the code is thanks
Old 07-25-2009, 10:13 PM
Kitt1993's Avatar
Kitt1993 Kitt1993 is offline
Re: air bag light
A thermal fuse is built into diagnostic monitor. If a short to ground should occur in air bag deployment circuit, microcomputer in diagnostic monitor will send a signal to fuse, causing it to open. Open fuse removes all firing power (battery/back-up power) from deployment circuits. This prevents unwanted air bag deployments due to damaged vehicle wiring. If you open the air bag module, you will see the fuse and a black resistor (usually black). Might want to try to find a replacement. Usually the reason these go out is b/c the clock spring is bad.
Bryan
Nick names for my Car....
Abe Lincoln, opcorn:
The President,
Lucky Number 5
