Go Back   Automotive Forums Car Chat > Lincoln > Mark VIII
Old 07-25-2009, 02:00 PM
matt_lucas3 matt_lucas3 is offline
93 Mark VIII hard shifting 1 - 2.
The transmission shifts really hard from 1st to second but is smooth the rest of the gears. Any ideas?
Old 10-31-2009, 08:44 AM
Markaholic's Avatar
Markaholic Markaholic is offline
Re: 93 Mark VIII hard shifting 1 - 2.
You more than likely have a broken lower spring in the 1-2 shift accumulator. This is a common problem with the 93 4R70W trans. The cause is a poor design of the piston, to small for the bore.
The fix is cheap and easy. Drop the pan, remove a snap ring, springs and piston will drop out. install new parts and your good to go.
Call Max @ 5 Star Ford. Tell him you need the updated 1-2 shift accumulator and he will take care of you. 1-800-866-1520 ext 236.
