Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 07-25-2009, 10:35 AM
Bisley Bisley is offline
Headlight problem fixed...no relay
I posted earlier about removing the headlight relays...but before I removed one, I found the problem . I turned on the headlights before I removed the relay and they worked....however when I touched the headlight switch...left headlight went out. With it still on I slightly moved the control and it came back on. I did a search and found a earlier post concerning the same problem...Harpoon Dodger did a reply to this post about his fix and after removing and disasimbling and cleaning the three contact points as he did in his reply....they work fine. Very simple switch and not a problem to take apart. This is a good forum ! Thanks for the information and a special thanks to Harpoon Dodger! Bisley
