Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 07-24-2009, 10:38 PM
96CamaroSS's Avatar
96CamaroSS 96CamaroSS is offline
2005 GMC electrical problems
I have a 2005 GMC Sierra with the 5.3L. Everything has been normal up to yesterday. All of a sudden I started the truck and all the gauges with the exception of the tach stopped working, also the abs and air bag light are on. Now the problem has gotten worse the power window now quit along with the door locks. I've changed the battery cleaned the connections, and had the alternator tested. All the fuses check out good. Could this be a bad ignition switch or some kind of body control module? Any help would be appreciated.
Old 08-20-2009, 01:49 AM
567234ta 567234ta is offline
Re: 2005 GMC electrical problems
check the voltage on the wires at the bottom of the underhood fusebox. (the wires feeding the fuses). i recently had a similar problem with an ignition switch, it was only giving 1.86 volts to one leg of the fuse box.
